AB Ultra3000 sercos drive not ready
Roth1984
Jan 2023
Arkansas
Good afternoon all,
We have a carton machine with 7 Ultra3000 sercos drives controlling various servo motors. From what I understand, It has worked for several years with very few electrical problems. Recently, we’ve been changing 0.5kW sercos drives like crazy. When we press the reset button, the drives begin their “synchronization” but at least one of the drives keep rebooting itself. And the screen will throw sercos ring faults. It will eventually reach “4” on the status display and the network LED is solid green. The module status LED flashes green (manual says not enabled). It has the enable bit, but the “bus ready” bit in logix is 0. None of the drives ever give a fault to assist. I’m out of ideas and could really use some advice. I’ve got pictures and videos I can send privately. Thank you, Skyler
logix5000 Sercos with ultra3000 drive, how can I get the marker status? why my marker postion is always 0? I want use this marker status to make...
1,528
Hi. I have a ControlLogix PLC with a SERCOS card which is going to be connected to an AB Ultra3000 SERCOS drive. Do I need to use an AB servo...
3,898
Hello all, I am currently trying to setup an Allen Bradley Ultra3000 drive connected by SERCOS link. I have played around with all the settings...
5,081
I'm having trouble figuring out how to have a limit switch that is an imput to the ControlLogix controller be the 'home limit switch' for the...
3,162
Hello, I have an issue with one Ultra3000 servo drive. I command an 1326AB-B520E-S2L motor and after 30 min the drive goes to fault with the E22...
1,643
