Studio V. 31.xx won't install
saultgeorge
Jul 2015
Detroit
535
Hi folks.
I got a "new" z-book here at a new job and I am having a lot of trouble getting Studio V. 31.02 to install. We have it on a server and I've tried getting it directly from Rockwell. BTW Windows 10 enterprise V. 1909 64-bit
They gave me a smaller laptop without the features engineering needed and I got it on there OK so I'm figuring it's a machine issue.
As one can see by the snips, I have V. 19 and 20 plus linx and I also reinstalled FTV Services platform.
The snip with the install summary rings a bell but I can't remember what that was about. Something about that C++ business.
Anyway I'm going to need 31.xx and 32.04 on here like soon. It seems like we only have 2 or 3 machines with v.31 and of course I have a modification to make to the program on one of them.
Any direction would be appreciated. Thank you for all you do for folks on here.
Respectfully,
I don't know if this will help but I installed v33 first on a new w10 laptop and then was able to install v28, 30,31,32 easily. I first tried v28 and was unsuccessful.
Hi, thanks. V. 33 was actually on there and one of the guys said to take it off. I'll try that and post an update.
Hi, OK I installed V. 33 and then went to the lower versions. I still couldn't install 31.xx so I searched the information in the install report in the first screenshot. I then tried method 1 in the second screenshot and V. 31 installed OK then. One of the other engineers said to download something for that C++ but I didn't need to. Hopefully this will help someone some day.
Probably someone will reply with "You didn't know this?!" :ROFLMAO:
Thank you so much for your time and help. I won't forget this one.
Something that might help you out: Rockwell now offers a first party multi version install for all Studios from V20-33.
They have it hidden under their "Additional downloads" section, if you are interested, I can post a link to other threads about it.
Regards,
PreLC
Regards,
PreLC
+1 Good to know!
Regards,
PreLC
Thanks!! That would be a great link to have.
When I have problems installing Studio on a Win10 I follow Rockwell's direction and go to the REDIST folder, then each subfolder and install that. Some things will popup a newer version is installed or that doesn't go with my computer, but once all the add-ons are installed Studio installs fine.
Every time I've ran into that (different versions), I've went into Add/Remove programs, found that Visuall C++ and repaired it, then install again.
I am a big fan of developing in Logix Emulate when I don't have access to a live PLC. That said I am running into an issue with not being able to...
1,537
Hey, First post here! Anyways I just started working at an industrial plant and was basically tasked with controlling the PLCs. I realized that...
2,183
When I try to open Studio 5000 Logix Emulate, it always throws up an error screen and shuts down. I've uninstalled and re-installed after a...
6,032
Hi guys, I had View studio 6.00 and it was working alright but we were forced to switch for 5.1 because almost all of our panelview are old. So...
5,751
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
103
