omron plc to barcode scanner rs232 communication
Sep 2019
bangalore
Brand: motorola
Model number: LI 4278
Cradle model number: STB4278
Rs232 cable: CBA-R01-S07PBR
To communicate with
Plc model: omron
CP1E -N30-DR
RS 232 Communication
thank you for your reply... i already done the communication Barcode scanner Li4278 having different barcode configuration for omron device and the important Parameter is communication timeout. in default 2s we should change 9.9s. Then it is communicated successfully..
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
70
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
171
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
137
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
198
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
127
