PC monitor addition to omron PLC.
skip83
Mar 2024
Tennessee
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant is stuck in the 80's. Our PLCs our omron CH I think with a Omron NS HMI. Just now installing ethernet drops to each PLC and adding ethernet cards. He wants this done as of yesterday. I am looking at some LED message boards that I think will be the easiest. I know I can use a PC monitor some how but I am unsure what is needed. Does anyone have any ideas or info. TIA.
I work in a similar environment. Lots of PLCs but no data collection capabilities. We have installed Vorne boards to track production. They are very simple and have a limited number of inputs. That said, they can collect basic data and display it locally. Also, if you can network them you can use their software to do further analysis.
We have a quad monitor setup with FT SE and we are utilizing a header screen at the top of every display. when we open a new page we abort the...
96
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
354
We finally replaced our Cognex Checker with an IV-3 and I'm wondering if can replace the s/w in the monitor with anything else. I haven't been...
103
Im very new to programmin,but i was wanting to try and set up a program that could monitor the speed of a roller. Would it be possible to use the...
158
Hi. I’m looking to replace a basic Shark power monitor with a newer one with communication options, probably PowerMonitor 5000. The existing one...
997
