GX Works 2 V1
parky
Oct 2004
Midlands
5,748
Interesting problem, about 3 years ago I needed to use the high speed counter C235 with input X0, in GX Developer its simple LD M8000 OUT C235 K32767 that's all, I tried this in GXIEC and there was a function that worked called Counter_M, this did not need an instance, however when I tried in GX Works 2 the only counters seem to be instance blocks so you cannot give them a counter number, I tried using a coil but would not accept the C235 or CC235 so I'm not sure how but I imported the function from GXIEC into GX Works and it compiled and worked, there does not seem to be the equivalent function in GX Works, See attached pic of code that I imported any ideas?
Problem Solved the function is OUT_C_32 this function is used for 32 bit counters doh..... should have used the scroll bar
o_O
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
333
PLC: Fx5u CPU As Per manual High Speed Input Module can add from Navigation window  [Parameter]  [Module Information]  Right-click  [Add New...
99
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
113
Hi Guys, I want to connect my 1769-L36ERM to a different network domain, is it possible to do it using only the dual ports in the Controller? Or...
223
I'm totally new to PLC's and I've just purchased an FX3U-14MR Mitsubishi Clone. I believe I need to use GX Works Software to program it but I've...
128
