s7-1200 basic HMI time remaining
shane_bac
May 2014
Derbyshire
23
I am currently using a HMI to set the time in a TP block and using the ET to show the value of the time elapsed on the HMI. How do I configure this value to show the time remaining? Any thoughts would be appreciated, thank you.
Will I need to store the value from PT and ET rather than just declaring the tags from the HMI to do the calculation as I cannot access PT and ET values in the calculation block inputs
that would be odd. o_O
how come you cannot access?
do you mean calculation block as code block in LAD?
but then why would you use calculation block from simple SUB operation...
I need to confirm that the can we convert the KTP1200 Basic PN to TP1200 Comfort HMI. I am using TIA Ver 14 and it shows the Device change option...
2,238
Hello everyone, I come across with connection issue between CP 1242-7 v2 gprs and Telecontrol server. SMS communication is working fine. I...
1,569
Hello, I have searched the website, from Siemens, but could not find a working link to the conversion tool from S7-200 to S7-1200. To install in...
1,615
Good morning, i have step7 10.5 basic that works fine with 1bd30 cpu, but it seems supporting only old cpu. now i would buy a 1bd40 cpu, but the...
1,209
Hello all, The problem I have is how can I load a IP address to the HMI. In my project I have set a IP address similar to the PLC but when I try...
5,922
