Hello everyone,
I come across with connection issue between CP 1242-7 v2 gprs and Telecontrol server.
SMS communication is working fine.
I cannot establish connection between them via mobile network. What I've done so far:
- my PC is set to fixed IP address
- to PC address several ports are forwarded (router config): 26860, 26861, 26862, 26864 and 55097 (also tried to check if ports are forwarded but only 55097 is open and I believe that should be enough)
- used my external IP adress as partner IP station address in CP hardware configuration
- installed CMT (configuration and monitoring tool) on PC
- added station to CMT and cant establish connection
What i've done wrong or what I should do?
Any suggestion is appreciated.
Thanks forward.
Thanks forward.
