What are the best Laptops for PLC Programming
MJ®
May 2002
I'm planning to buy a new laptop, my old laptop
a compaq is about to conk out on me anytime soon.
So i'm asking you guys..In your opinion and experience
what is the best laptop out there right now for PLC programming?
Remember that you need a serial port! That should narrow your choices down to just a few manufacturers... Keep in mind that most don't come with one anymore.
Make a list things you MUST have (like a serial port maybe?) and how much you're willing to spend, then decide which one "fits the bill" the best...
I have had excellent luck with the 2 Toshiba Satellite Pros I own (though they're starting to show their age). I have a preference for the trackstick (over a touchpad), and as far as I know, they're only on the IBM Thinkpads and Toshibas (but Toshiba is slowly phasing them out as well) :(
I had a lot of problems with hard drive controller failures on my last Dell, but that was years ago.... Hopefully that's been solved since they hired Steve (You know, the "Dude, you're getting a DELL" guy) :D
Happy shopping!
-Eric
I have been using Dell's Inspiron 8000 and 8100 with Win2K for a couple of years now with absolutely no problems.
They have more ports and options than I will ever use.
>>Ports: Serial, parallel, USB (2), ethernet, docking, external monitor, PS2, IEEE 1394, PCMCIA (Type 3), S-video.
>>Other: 1.2GHz Pentium III, 256MB RAM, 20GB Hard drive, floppy, 56K modem, 24X CD-ROM, Infrared comm., nice leather carry case, 3 year warranty, and lifetime phone support.
List price is $2942 before discounts.
Courtesy of the company.:nodi:
I have a new Compaq 1ghz laptop and a IBM Thinkpad 390E 300mhz..the Compaq isnt in the class with the IBM. Yes the cpu is faster and it has a larger hdd but overall the IBM is just plain better.
With ALL the newer laptops you have to BEWARE, they have a tendency to build them for Win2k or XP and have no drivers for backwards compatibility with Dos/Win9x. As stated above most do NOT have a serial port either and you have to swap things like cdrom with floppy, which to me is a PITA. Expect to pay a premium price to get one that has floppy, cdrom and serial port built in (not swapped) but its worth it when it comes to eliminating problems and comsuming time better spent later on.
Personally if I was going to buy a laptop to use for plc's and that would be used in harsh environments etc. I would look at older/used models that were top of the line when new. My IBM is a good example, when new this thing cost around 5k, but models similar to it can be found on ebay for less than $500 now. The other advantage to this is they have non working models that can be had for $100 more or less that make good spare parts. I had to replace my keyboard (spilled my darn drink on it) and found it cheaper to buy whole non working unit than just a keyboard. I have bought 2 units like this that technically will work if I swap parts around, so I have the satisfaction of not worrying about the laptop dying...I even have the hdd duplicated. The other factor in buying slightly older models is using WIN98, these machines work well with it and has a viable DOS base that most plc's work well with if needed.
Whether you buy new or old the old axiom applies BUYER BEWARE.
Know what you want and make sure you get it from the start, dont try to addon later.
The Dell Inspiron 8100 or 8200.
It has a serial port and best of all it has a 1600x1200 display. Once you use a 1600x1200 display you will not want to anything less. The 1600x1200 display allows one to see more code/ladder/data/windows at one time. This reduces the amount of time wasted mickey mousing around.
We have bought 3 8100s in the last year.
And one to dodge is any model of ACER TRAVEL-MATE. They just drop to bits. They are made of hard brittle plastic and cannot take the slightest knock. Cracks appear from every corner, the screen hinges are faulty and break. I wasted £1000 on one. It is no longer portable; just the job for on site programming eh. It sort of ruined the my image, turning up well dressed, laptop briefcase in hand and then pulling this cracked and screen hanging off thing out of the bag.
WELL HERE IS MY TWO CENTS. 1. MAKE SURE YOU HAVE PLENTY OF PORTS FOR COMM. 2. MAKE SURE IT HAS A MOUSE AND TOUCH PAD THAT YOU AND YOUR PEOPLE CAN USE QUICKLY AND ACCURATELY( SO WHEN SH*# HITS THE FAN AND YOU HAVE TO DO SOME ON THE FLY PROGRAMMING). ECT. ECT.
I have to second the Acer Travelmate objection. We have had several and they do not hold up well at all. Also the Fujitsu's don't hold up well either.
We are now using Compaq Armada's and are having really good luck so far with them. Low end 800mhz models are around $800 at CDW. At least this was the case two months ago when we bought our last one. :p
You didn't ask, but Windows 2000 is my OS of choice. It's been stable for me for a year now (that's at least a 1200% improvement), and it's compatible with most PLC software.
If you need to run some "legacy" software, Win2000 makes dual boot pretty painless. Many of the guys posting to this site are running dual (dueling?) operating systems on their laptops for this very reason.
My laptop is an HP Pavilion N5350. It hasn't travelled the country much yet. But, I've been lugging it around daily and dropping it off tables for a year and all its pieces are still attached.
Once you check the comm ports on your new laptop, check the battery holder. Those batteries are the first thing to fall out of most laptops!
AK
I use a really nice Etch-a-Sketch.
Reboots with just a flick of the wrist.
Actually I prefer my Dell Latitude.
The CD-RW comes in handy for archiving programs.
Besides the serial port for comms there is a
100 mb nic for ethernet communications
i depends on what plc software you use. for allen bradley i go with a toshiba because it seems to support the allen bradley software alot better than other laptops letting you transfer data back and forth at the same time. dude dont get a dell. I have had some luck compaq also
PLC softwares have usually a low need for number crunching CPUs. The key thing will be com capability, OS and price.
I have a few low-end Toshibas. They perform well but are not has good for viewing Star Treck movies whyle on a plane...
Can't win'em all!!!
Good Morning , I would like to invest in new laptops for the plant floor. Would like Serial Ports , Ethernet Ports , USB ports , and...
6,623
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
572
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
695
I am going to need to use HART multi-drop in order to handle a series of Vega Radar units. There are a lot of options and I'm wondering what...
281
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,230
