Hi
This is the first time i try to have OP communication over profibus but so far i havnent been able to get it working.
What steps are required to get it working? it would help alot if someone told me the basic steps so i don't waste time on doing things i don't need to.
This is how i have done it.
1.Configured the 300 cpu in hw config and configured the DP/MPi port to be a profibus port with adress 2 (master)
2. Created a small testing project in wincc to read some of the db's in the CPU.
3. Configured the connections in wincc:
HMI device:
Baud rate - 12000000
Adress - 1
Network:
Profile - Dp
Highest station address - 31
Number of masters - 1
PLC device:
Address - 2
Expansion slot - 2
Rack - 0
Cyclic operation - Check
4. Connected the Dp cable between cpu & Op and terminated it in both ends
This is the basic stuff i have been doing but i have also been trying with lots of other stuff when i didn't get it to work. So does anyone have a clue about what i have missed?
Do i have to setup a OP panel in the hw config also? i had one there but it didn't seem to make things any better
HMI device:
Adress - 1
Network:
Profile - Dp
PLC device:
Address - 2
Expansion slot - 2
Rack - 0
