Modicom Quantum software
stooperbike
Oct 2004
New Hampshire
78
Hi, its been a few years since I posted anything on this site. I am wondering if someone could point me in the right direction. I have a customer that has a Modicon Quantum PLC. I actually did the programing on it back in 2002, they have asked for some upgrades. But I am not sure what software is available to do this? I used Concept originally. I need to upload for now, just want to get a backup. Ohh it has Modbus Plus and I remember it used a PCMCIA slot to communicate. This does have a separate Ethernet card but I honestly don't remember if we used it for uploads and down loads.
thanks!
The Quantum platform can be programmed in ProWorx32 or ProWorx NxT which are both obtainable from Schneider.
Otherwise you always have Unity Pro- but you will obviously have to convert your project.
Quantum programming options
Does the customer (or you) have the Concept files? Concept made lots of files for a project, so it won't be just one file.
You can (maybe, see below) upload from the PLC using any of the comm ports (Modbus RS-232 or Modbus Plus on the CPU, Ethernet on the NOE). There used to be a PCMCIA MB+ card back in the days of computers with PCMCIA sockets. You can get a USB MB+ card, but it's not inexpensive so I'd guess that you would be better off with Ethernet.
Anyway, here are the basic options:
1 - Concept could create IEC programs and 984 Ladder Logic programs. On a Quantum, depending on the CPU, it could be either one or both. The 984 editor in Concept was quite possibly the worst 984 editor on the planet, so I'm guessing if you had used 984 you would remember that due to have the sort of fond memories often associated with dropping large heavy objects on bare feet.
2 - Assuming it was programmed in IEC Concept you may or may not be able to upload from the PLC. There was a project setting to download the source version of the project to the PLC, but of course that wasn't on by default when you created a project. It pretty much doubled the memory use of the PLC, which is probably why it was defaulted to off. If the project is in the PLC you will be able to use Concept to upload from the PLC. If the editor project is not in the PLC and you don't have the files, well, going thru pockets for loose change come to mind...
3 - That involves having Concept, or having access to Concept. Concept is a 16 bit application, so don't bother trying to install it in 64 bit Windows. Concept was also rather version sensitive, including service pack and hot fix numbers, so if you don't have the right one you may have an issue.
4 - If the system was done in 984 Ladder Logic and has no IEC then life is somewhat easier. You can upload 984 using virtually any program that can edit 984 logic. Modsoft (DOS), ProWorx (DOS), ProWorx Nxt (16 bit Windows), Concept (16 bit windows), ProWorx 32 (32 bit Windows) - they're all obsolete and no longer listed for sale according to my Schneider rep. You can buy Unity (probably the XL version since it's a Quantum) that will be able to edit 984, but only works with some of the Quantum CPU models. A 984 upload will have no comments or other documentation unless it was done with Concept and the download editor option was turned on. Programs downloaded via ProWorx of any flavor won't have any documentation.
5 - If you do have the original project files you have a slightly easier time. You'll need the project export file (it's got an extension of .ASC) and Unity can import that, mangle the hell out of the variable table, make some things work completely differently, and create a kinda functional Unity program. Of course you'll need a Unity CPU, which your Quantum may be (140-CPU-434 or 140-CPU-534) to actually use it. If the CPU is a 140-CPU-113-02 or -03 then Unity can't use it. If you don't have the exported file (.ASC extension) but do have the project then you can create it using tools with Concept.
6 - Don't forget that ALL Quantum CPU's are end of commercialization at the end of this year, so you can buy repair or exchange, or maybe somebody has one on the shelf, but otherwise the pockets and loose change thing comes to mind.
If you don't have Concept and you think it was done with Concept then I might suggest contacting your local Schneider distributor and Schneider rep. One of those might have access to Concept to be able to help you out. I do have Concept, so feel free to send me any questions.
Kenschuck
Thank you very much for that response. That is a big help. I am honestly trying to proceed with a lot of caution on this one. The whole program was done in IEC function block so anything ladder will be out, also I am pretty sure it was done in v2.2 sooooo. I think this is going to be a mess, I was able to find Concept 2.2 on ebay for 6k lol. Thanks again for the help!
Hi folks ! Got an older Modicom BM85 and I suspect that it's not passing data to ModBus+ network. We had a power loss for a few days and I suspect...
70
Hi im in dire need of help programming a telemec modicon plc if anybody can help?
2,186
I want to communicate between Siemens S7 315 CPU and modicon 984 CPU with Foxpro software throught profibus,315 as a master and 984 as a...
1,615
What is "Modicom PLC programming environment " that I have seen in some discussion groups.Is it a type of plc?
5,244
da32now
D
hi All Can you please help me to find the right software to open Zip backup of 434 12A PLC? Any major steps I need to know when opening? Regards
72
