How to write multiple registers with S7-1518F + Modbus
Stefan1980
Feb 2016
Sweden
Hi, i have to write to multiple registers to reset alarms to several NSX 100-630 (Schneider Electric)
I have to write to all these registers to reset all alarms for this unit (and repeate for everything else)
And i think i figured out how to send all registers at once, but i am unable to test it right now.
Have i assumed correctly that MB_PTR_DATA is setup correctly to reset the alarms?
Also, i am not sure if i should write to 3xxx or 4xxx register with the offset 8000-8005.
AcroRd32_2017-02-22_10-12-11.jpg Siemens.Automation.Portal_2017-02-22_13-18-06.jpg
One of the better sites to explain modbus is the following:
http://www.simplymodbus.ca/FAQ.htm#FC
Register/Coil Function codes for multiple writes:
Function Code Action Table Name
16 (10 hex) Write multiple Analog Output Holding Registers
15 (0F hex) Write multiple Discrete Output Coils
I have not worked with your equipment before, but it looks like this will work. I would test the system out with a read command to ensure that communication is established and working as expected. Then move onto writing information.
Just a thought. Hope it helps.
Regards,
My first time using a SEL 3350 RTAC (or any RTU for that matter). Setting up with most Modbus TCP functions - both Server and Client - seems...
1,554
Dear Experts, Can you help me, I am using compactlogix cpu with ILX34-MBS485 card as Rs485 master in serial modbus network to make communication...
2,871
Hello guys I need a help from you all to complete my assignment I have more than 1000 tags in my project Now I have to make cause and effect chart...
3,497
Hi, I've used modbus quite extensively in the past - but always based around reading holding registers and setting the odd coil. I've now got an...
4,195
Sir, At present i can write one parameter at a time, but how to write multiple parameter in sinamics s110 using SFC 58 in S7-300. And also...
2,394
