Schematic Help
samvivi7
Apr 2016
NJ
50
Hey Everyone,
I need a little help with the attached schematic.
On the Input card, I have;
COM 0 and COM1 to 0VDC --- other side of the sensor is connected to +24 VDC
COM 3 the same way
COM 2 the opposite
On the Output card;
VDC and NEUT for the card power
DC0 --DC2 are group power
DC3 --DC5 are group power only when 1CR is energized
Do i have this right???
Thanks for any help
outputs are all relay so you can do what you like, and yes the relais is correct.
however the inputs i am not sure depends on the input type card.
Hello, fairly new to plcs I’m tasked with installing a PE to a micrologix1200, in the attached picture I/14 is the PE I’m installing it’s going to...
995
This is my first IO-Link project. I am having trouble figuring out how to draw this in ACAD-E. How to show the system as well as the wiring to...
1,800
There are so many different ways to tackle the first sheet of the schematics. I've seen some people with a cover sheet, followed by several...
2,642
Which Style to you expect to see on a drawing? Which style to you prefer? Keep in mind this being used on very large projects Style 1 Style 2
21
6,853
Hello, A couple of questions regarding NEMA schematics and terminal block labeling. 1) I am familiar with the DIN designations for components...
3,172
