Does anyone know how to make CFC editor/compiler to create same instance DB number for modified CFC chart objects? Sometimes, after change, instance DB number is different then from previous compile/ or Block Type change. I need it to connect some HMI elements to instance DB created by CFC and because of that reason after change CFC block must be connected to same instance DB.
