IP Address and BOOTCP
Jul 2017
Corby
Hi guys, I am allocating IP Addresses to a CPU. and by accident assigned the IP address to the wrong card and had decided the BOOTP/DHCP. Was just wondering if there is any possible way to fix this and remove the Ip address. any advice would be great.
thanks
Can you see the PLC in linx? You might be able to right click the processor and bring up the module configuration and be able to set it back to dhcp.
You can use the bootp/dhcp utility to reset the IP as long as you know the MAC address and can hook a cable directly to the device you want to reset.
Open the utility, add a new relation, enter the mac address of the device you want to reset , enter the IP you WANT it to have and hit Ok.
Then go to tools - relation list - and reset modules network settings to factory default. This will turn bootp back on and it should show back up
Edit: Nm, Iggy sorted ya :)
157
i have two plc 1. s7-1212dc/dc/dc ip; 192.168.0.1 2. s7-1500 1513-1pn ip; 192.168.3.2 i need to get data from plc1 to plc2. any idea how to do...
166
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
222
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
108
Hi Guys, Is it okay to have Redundancy ControlLogix Processor IP address set to DHCP? I had Static IP address on it but removed it via RSLinx...
252
