FactoryTalk View ME - Visibility Based on HMI's IP Address
nievesdelimon
Mar 2018
Queretaro
37
I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The customer wants to use only one file for two HMIs on opposite sides of a line and there's only one layout which has the wrong orientation on one side.
I do not know about the IP address question. But I have done applications where there were multiple stations, they were almost all the same. The startup screen had the operator select which station they were at, then the proper screens were loaded for that application. Just an idea. First screen asks? Left or right side station?
Yep, Ken's idea is the correct one in my opinion - what happens if a tech changes the IP address on the station one day to something you don't anticipate?
You could even make it memory retentive and hide the ability to change it in a 'settings' tab somewhere.
Yep. That's exactly what I'm doing. Thanks!
Hi all, I have an ME project in which I am using a "Wedge" object to display the state of some sensors. These have "Visibility" animation, which...
2,329
I am using a Global Object Touch animation to open up a popup window. Can you use one of the Parameters you pass though to adjust the visibility...
3,187
Maybe someone here can help me or tell me this isn't possible. I have two CLX L71 processors with one HMI. They are for two slicers that are...
2,560
I have a button on my HMI that I only want visible under two conditions. One of them is a numerical value and the other is if a bit is on...
9,826
I am trying to set visibility on a button using a PLC tag that is a string (03820 77). I used this statement...
1,562
