FactoryTalk View ME Wedge visibility
daba
Jul 2004
uk
5,401
Hi all, I have an ME project in which I am using a "Wedge" object to display the state of some sensors.
These have "Visibility" animation, which the user has the option to turn the display of the sensor states on or off.
However, when the option is turned Off, I can clearly see the outline of the wedge object, when it should be invisible.
This does not happen on the sister SE project, and the wedge object properties are identical, SE and ME.
Does anyone know how I can get this functioning correctly ?
TIA
Sure, nothing special, the PLC tag for the state, and the visibility switch.
Is it possible you have multiple objects? The white lines usually indicates an object with an unknown tag or no tag.
Got it ! They were tagged to xxxx_OCCUPIED, when they should have been tagged to xxxx_OBS (Obscured - these are Ultrasonic sensors detecting trains over Points).
Many thanks for the heads-up !!
So.....Just did the same here with two tags and I'm seeing normal operation. Could you possibly have grouped objects with the animation causing the wedge to disappear and revealing the other object?
EDIT: Nevermind, I see you got it
OG
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
154
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
131
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
178
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
201
