Hello, I am just wondering if you have any ideas to help me with this. I am currently working on a barcode scanner reading via serial.
This is Logix Designer 30.11
I need to search the sint and start after the first R and then end with the little r. The sample serial that I sent was 123456 which can be seen below. Basically I want to copy only 123456 and put it onto my hmi. but they will not always be 6 characters so I do not know how to copy variable sizes and not have the "r" show up with a bunch of zero's behind it.
Thank you,
Thank you,
