Sorting String data using Structured Text
No, my recipes are stored outside of the PLC, I send the active recipe data to the PLC. This data doesn't change when/if the PC/HMI is disconnected. Even if you store the recipes in the PLC, you still have to have a way to select them.
In my manner the recipes can be sorted in many ways, names, date created, data last used, most used, etc. Try doing that with the PLC. :)
SQL can manipulate the recipe data, and give everything you are asking for, but your PC must be connected to the PLC. What happens if it isn't connected ?
If you are adamant that your recipe data remains outside the PLC, why are you asking for a STL solution for sorting, inferring that recipe manipulation is done in the PLC ?
Thanks, I see your point.
Smaller applications may not be connected to PC at all and the HMI doesn't (or may not) have that capability.
I have worked on small projects using AB Micrologix but now we want to take a photo, process it online, and sort based on returned variables...
323
Hi, I have just started with WinCC unified (v17) and there are alot of things I used on Comfort but now are not available. Currently I am finding...
2,834
I'm trying to be smart about naming my tags so things automatically group together alphabetically, but for some reason it doesn't work like I...
3,638
Hello friends. There is an int type, number that I got from the DataBlock. For example, the DataBlock address is Db1.dbw0. Here's what I want to...
32
10,441
Good afternoon all, I am working on a college project where we have to sort 3 different color legos. Orange, Black, and Tan. I am using a color...
30
6,769
