OT: linear slide with position feedback
bce123
Feb 2011
texas
1,177
I looking for a linear slide with position feedback. the slide must be at least 3ft long and cary around 1 pound. A penumatic driven unit is in place now however I don't know the MFG. anyone out there have any ideas
Thanks,
Thanks,
Are you looking to stay pneumatic or is an electric actuator an option?
I use Mitsubishi servos with Festo actuators. Very solid and reliable.
I know pricewise the pneumatic option is probably a good deal cheaper when all is said and done.
Dave
depending on your accuracey you could use a inear potentiometer
they can be fitted with the existing cylinder.
then change the Pneumatice to dual 3/2 valves and lock the cylinder
this is very rough but what do you need
I am not replacing or using the existing slide just looking for something close to use in a measurement app. I intend to use the slide to move a laser so as to detect the end of a pipe and than record position to get length. I will most likely need three of these so cost could be in issue as budgets must be approved.
attached a pdf file that i hope makes sense. Looking at some type of linear assembly that would have a 220v type small motor attached to the end...
5,563
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
244
Hello, We are currently working on a project that involves connecting a linear potentiometer to our Beckhoff PLC. After researching, we...
229
hi! Has anyone experience doing linear interpolation for servo motors using omron CJ2M PLC and CJ1W-NJ413 PCU. If you do, can you show me...
175
Hi, I have an application that currently utilizes SEW drives and programming that we are attempting to convert to Allen Bradley CompactLogix and...
1,181
