Programming help for AB PLC
hegde10122
Aug 2004
I am supposed to program for the following data:
There are 4 motorised valves and the resistance mounted on motor shaft is used as percentage opening data to plc. The PLC module is Micrologix 1200 AB plc and 1762-IR4 RTD module. The value of the resistance lies between 0 to 600 ohms.
Hello All, As you can guess by the title I am a total noob to programming PLC's. So my problem is that I have an old Pallet wrapper that uses an...
21
4,967
Hey all, I have this old code am trying to convert. Never worked with this PLC before. The 2 rungs are attached. What is happening here? What are...
5,181
Hello Guys, I'm new to PLC programming and a course I'm currently studying has asked a question and requested we use a shift register. The...
20
5,997
I am in need of some help to perform a simple task in RSlogix5. We are using RSview32 to control heat zones on an extruder barrel. We have...
1,549
Hi, I'm new to this Forum. Can anybody help me with following. I want to reprogram an old Matsushita (Panasonic) NAiS FP3 PLC. CPU model no...
3,158
