We are using a limit switch with 2 contacts. One of them is wired to a PLC (24VDC) for alarming and the other one is wired directly to the CCM and is used to feed a coil (127VAC) that will act as an emergency stop for a motor.
As both signals are for "control" purposes. Can we run them in the same conduit? If so can you point me to a normative that says so?
Thanks in advance!
Thanks in advance!
