PLC 5 analog input scaling question
M15cell
May 2012
Los Angeles
Hello everyone,
I have a plc 5 input card receiving an input from a conductivity
Transmitter where 0ma=0 uhms and 20ma= 20,000 uhms
The raw min is 0 and Max is 4095, I’m not very familiar with plc 5 but I understand there’s no SCP option.
What would be the best way of scaling this in the ladder logic.
Hi all, I’m an electrician with limited knowledge of PLC circuits. Typically I will see simple 2/3/4 wire terminations for transmitters on...
26
1,262
Hi all, I want to catch min piks of an analog signal when digital signal is on(pls see the attached oscillogram). My hardware is 5069-L306ER CPU...
995
Hello I have a analog input signal that is bouncing a bit. The PLC card is a 1769-IF8 I changed the input card filter setting from 60hz to 50hz...
4,855
Dear all I am using delta AH530 RS- 2 cpu with devicenet communication and now I am getting problem while configuration of AH6xa-05 which is...
1,038
Hello everyone I got problem during practical. I am using delta plc model:DVP20EX00R2. Problem is that when i give 7v dc supply through bridge...
2,432
