interfacing with an older CompactLogix controller; Logix5K ok?
defcon.klaxon
Feb 2015
Far NorCal
616
Quick question for y'all. Went by a new client's plant today, and they have an older CompactLogix controller; it's an L32E. From what I have gathered, they're discontinued and the 5370 series replaced them. My question is, can I use Logix5K (V24) to connect to it, and grab the existing program? I can't find anything to the contrary, but wanted to verify.
You need to have the version of Studio5K/RS5K corresponding to the processors firmware, which you can determine with RSLinx. If you have TechConnect you can download the appropriate revision. After version 10 or so multiple versions can exist on the same computer.
As long as your programming software supports the firmware revision that the Compactlogix is running, you can connect and upload.
If you are running V24 and the CompactLogix is V16, you will have to load the old V16 Logix5000 in order to connect.
I have one V16 ControlLogix left. And I get reminded that I need to install the old V16 .. twice a year or so
... can I use Logix5K (V24) to connect to it, and grab the existing program?
Afraid not...You will need RSL5K V.20.04 or lower, depending of the CPU firmware level.
Firmware Revision 20 is the highest the old 1769-L32Es CompactLogix would accept; chances are the customer's one is running something lower than 20.
Thanks for all the info guys. I do indeed have TechConnect so what I'll do is use RSLinx to figure out firmware version, and then obtain appropriate version of Logix.
I have a Cognex Insight 2000-130 camera that I'm trying to get talking to my PLC. Both are connected to the same router via Ethernet. Thus far...
1,231
Hi, I am picking up a project started by a predecessor who is now out of contact. It is a Siemens S7-1515F PLC system - but the query is how you...
740
Hi everyone, I've got to interface 4 x Mitsubishi Q series PLC's with an Allen Bradley Compact Logix PLC using a Red Lion Data Station DSPLE000...
505
hello i want to read temperature data from Masibus UT94 temperature transmitter which is giving data on RS485 port. i have assigned ID:-30 and...
1,059
Hello I am very familiar with ladder logic and PLC programming, however I am new to Allen Bradley, ethernetIP, and interfacing measurement...
1,025
