plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old March 17th, 2023, 08:33 AM   #1
advmin
United Kingdom
advmin is offline
Connection problem of 1770 kfd with devicenet and laptop
Hi all,
I really need some advice for establishing communication between 1770 KFD with DeviceNet and my laptop.
1. What cable should I use to connect my laptop (no serial ports) with the KFD module? (I am using a 1747 CP3 USB but the led status is off for RS232 in KFD). I had seen some posts saying 1747 cp3 can be used so it means 1747 cp3 with usb end is the troublemaker?
2. Blinking green on module status is the only LED showed up yet on KFD. (network led is off for the 1769 devicenet scanner also). What steps should I follow to establish a connection between kfd with the DeviceNet scanner and laptop ?
(I am super beginner in this field with some basic knowledge)
thanks in advance!
Old March 17th, 2023, 09:10 AM   #2
arpus4KM
United States
arpus4KM is offline
https://literature.rockwellautomatio...n006_-en-p.pdf
page 16 shows pinouts for connecting to a standard DB9.
you can also use a 1747-cp3, 1756-cp3 or 1784-cp10 to make the connection. The DTR, DSR, and DCD lines should be tied together on the KFD side, as well as the RTS/CTS tied together. if you need to try different wiring to make sure..
you'll need RSlinx and the devicenet 1770-kfd, SDNPT driver to get the link established after that.
Make sure you use a good converter like the 9300-usbs (rockwells), or Tripplite USA19-hs
__________________
-Ian
Old March 17th, 2023, 10:19 AM   #3
advmin
United Kingdom
advmin is offline
thanks, Ian for clarifying my doubt.
I am ordering a 1747 cp3 and usa19-hs.
I will update soon.
cheers and have a great weekend.
Old March 17th, 2023, 01:35 PM   #4
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
Let me clarify about the serial cable:
The 1747-CP3 and 1756-CP3 are specifically built to connect a PC to an SLC-500 or ControlLogix controller serial port. They are "null modem" cables that swap the Rx and Tx pins internally and have a convenient right-angle connector that makes them fit cleanly under the processor door.
When those controller serial ports are set for default (non-hardware-handshaking) configurations, only the Rx, Tx and GND pins are necessary. So any null modem cable with DB9F ends will work to connect to the serial port of an SLC or ControlLogix, including the cable that comes with the 1770-KFD.
But the 1770-KFD and the RSNetworx serial driver require more than just pins 2/3/5. The pinout is shown on page 14 of the User Manual for the 1770-KFD (published in 1996). The 1747-CP3 and 1756-CP3 lack those features.
In my opinion if you don't have the cable that came with the 1770-KFD, you should build one from scratch. Or, you can build a plug adapter that includes those jumpers and give it a cheery "I Love DeviceNet, Soon You Will Too" label.
Old March 17th, 2023, 01:46 PM   #5
joseph_e2
United States
joseph_e2 is offline
Quote:
At my last place, we had "several" devices that required unique serial cables. We were always scrambling to find the right cable, so I got some double-ended back shells for DE9 connectors. We configured the wiring inside the shells to take the place of whatever cable it was and labelled the ends as to which end went towards the PC and which towards the device. That way, we could grab the adapter and any standard 9-core serial cable.
That device you linked would have made that much easier to build...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1770 KFD showing Autobaud failed advmin LIVE PLC Questions And Answers 2 March 16th, 2023 04:10 PM
DeviceNet -RSNetworx address problem Doug W LIVE PLC Questions And Answers 4 October 15th, 2011 01:25 PM
Problem uninstalling RS DeviceNet conorwa LIVE PLC Questions And Answers 2 June 13th, 2007 09:12 AM
DeviceNet & 1770-KFD Serial coms problem 69FIREBIRD LIVE PLC Questions And Answers 0 October 17th, 2006 07:06 AM
DeviceNet Linx problem R_C LIVE PLC Questions And Answers 8 July 26th, 2005 11:35 AM
