Adam6050 to S7-1200
Jezz
Dec 2002
Kendal
399
Hi All,
I'm wondering if it's possible to get a siemens S7-1200 to read the inputs from an Adam 6050 unit via Modbus TCP , any one got any ideas?
Modbus can be very frustrating but if you keep going you tend to get there in the end. From a S7-1200 I have managed Modbus TCP talking to a Linux embedded computer that converts it to Modbus RTU to read data from an ABB ACS355 VSD and a Mains Supply multimeter. Be prepared for some diagnostics, especially over TCP. Wireshark means you can look at the data going to and fro and see what the S7-1200 is sending out and if the remote device is responding. You probably won't get it working in an afternoon, so give yourself some extra fiddling time. Make sure you have an up to date firmware on the PLC and at least V14 TIA Portal.
YouTube has some useful videos and the Siemens forum has more information again:
https://support.industry.siemens.com/tf/ww/en/
As long I know it can in theory be done That will do for me ,I've got a test rig set up here so I'll have a play on that.
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
255
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
130
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
179
