Reading a USB RFID Reader Input on a AB PanelView Plus 1000
RobertStewart
Oct 2010
Glasgow
Hi everyone,
I have been having some trouble with a project I am currently working on. The end user will have an RFID fob, which they swipe, and which will identify them to the HMI. The USB RFID reader however appears to work exactly the same as a USB keyboard (I can see the data stored on the fob if I have a text file open and active on my pc, then scan the fob). Is there anyway to have the HMI run a screensaver which will be stopped when the fob is swiped, and pass the fob code on for further processing? I have looked at trying to get textboxes, much like Visual Basic, and cannot find the control on FactoryTalk View to do this, but it has been suggested I try and just trap the input as it arrives. Can anyone help?
Thanks!
Hi, Quick one passing through as I'm quite busy at the moment... Two-day head scratcher here trying to flash upgrade a bunch of out-of-the-box...
11,007
339
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
149
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
129
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
276
