RS232,422 to 485 coverter and rs 422,485 to USB conveter
gherz817
Oct 2005
PHILIPPINES
58
Hi everyone,
I need a rs232,422 to 485 cnverter and 8 port re422,485 to usb converter. What brand could you recommend that is tested already. What specifications should I look for buying a conveter?
Thanks...
gherz817
B and B electronics also has some good converters. Adam -4520-d2 is also an excellent converter in that it will simulate any handshaking allowing you to use only two wire configuration regardless of handshaking signals generated by the software. I've managed to get this one working on lines that other converters wopuld not work on regardless of how I wired those lines. Price is about a 100 dollars higher than lower end converters
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,061
I have a Hitachi interface converter Rs232/Rs422 cable that I'm trying to connect a PC to a D100. When i try to connect, it tries for about 30...
1,744
Hi I wanted to control 4 Displays to switch input from a PLC with serial interface. The Display can be controlled via its serial port with ASCII...
1,287
I want my HMI G07S sending data to both serial port RS232 and RS422 at same time, is it possible? if not, how can I switch the port...
1,885
Please, if anybody has this Siemens RS422/RS232 Converter. Please inform me. I don't know where I can find a stock of this. Order Code...
1,608
