Can I make RS232 and RS422 of Redlion G07S at same time?
Ya-hoo
Jan 2015
Calgary
I want my HMI G07S sending data to both serial port RS232 and RS422 at same time, is it possible? if not, how can I switch the port programmatically?
Thanks a lot for your kind help.
Ya-hooo
Hello OkiePC,
Thanks for your reply.
I was confused when I read the RedLion manual because it states that if either port is used for a slave protocol, the other port will be unavailable.
I am not sure if both port should be slave protocol in my application, the Redlion HMI will send data through both serial port to rig.
I appreciate your help.
Hello OkiePC,
I'm just jumping in with a comment without addressing your main question. Your original post says that the G07 will be sending data and then in your second, you reference slave protocols.
In my experience, "sending" uses a master protocol, "replying" or the like uses a slave protocol (via gateway blocks) so wouldn't apply to your situation.
If you want to clarify what you are doing and what devices you will be communicating with, we can probably provide additional help if you still need it.
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,049
I have a Hitachi interface converter Rs232/Rs422 cable that I'm trying to connect a PC to a D100. When i try to connect, it tries for about 30...
1,740
Hi I wanted to control 4 Displays to switch input from a PLC with serial interface. The Display can be controlled via its serial port with ASCII...
1,283
Please, if anybody has this Siemens RS422/RS232 Converter. Please inform me. I don't know where I can find a stock of this. Order Code...
1,605
Hi all. I am having trouble getting a Siemens OP277 and an AB SLC504 to talk to each other via DF1. The older panels OP25/OP27/OP270 had an...
2,094
