TWIDO Power up after power loss program position
jsoulier
Apr 2011
St. Brieux
I have a PLC running a multi stage press that we had the power fail on a couple of times. When the PLC was powered back up, the grafcet position was held and it continued to run through the rest of the cycle. How do I set up the TWIDO so that it resets the program and the varaibles upon power up and still hold a count value of completed parts.
Thanks,
Jordan
I have found an EEPROM available here is the excerpt from the data sheet it mentions the tranfer of internal datawords to the EEPROM but it still makes no mention of this data being retentive. Sorry i cant be of more help.
Memory cartridge​
(optional)
Cartridge type TWD XCP MFK32 TWD XCP MFK64
Memory type
EEPROM
Memory capacity Ko​
32 64
Save/transfer program and internal words​
All modular
base controllers
Base controllers
TWD LMDA 20DRT/40D
pK
Program size increase​
– 6000 instructions with base controllers
TWD LMDA 20DRT/40D
pK
take a look of system bits %S0, %S1 and %S13. Program crafcet to go to initial state/reset state if some of bits changes.
Hi guys!! I'm New here and new with this type of plcs i have TWDLMDA40DTK and i need to get a copy of the program and i don't have an original...
685
Dear friend, how to read the input register (3xxxxx) of device from twido plc. i have tried the comm macro but it always read the holding register...
1,567
Good, how do I control through an Analog output of a valve, that is, open the valve from 10% to 10% until it reaches 100%, and then close it...
2,237
Hi! I bought a secondhand Twido base unit to help me learn programming and also faultfind expansion modules (one of my customers machines uses...
1,684
We're a second hand machinery merchant. We've just had a machine arrive that has a Schneider Twido TWDLCAA24DRF PLC and a Magelis XBT-R411 HMI...
2,399
