Problem with Twido TWDLMDA40DTK
ThePhantom
Nov 2023
Egypt
Hi guys!!
I'm New here and new with this type of plcs
i have TWDLMDA40DTK and i need to get a copy of the program and i don't have an original cable so i made a one with rs-232 & Mini Din8
the wiring i did is
rs-232 ---> Mini Din8
2 --> 5
3 --> 4
5 --> 7
6 --> 3
now when i'm trying to connect via TwidoSoft_V3.5 i got
"The Controller connected to the PC is not supported"
what does it means and how to fix it?
I think you will find it is 485 not 232 Not absolutely sure but I seem to remember for 232 you have to add the 232 module.
Looking at the pic I copied you will need a 232 to 485 converter. perhaps ebay or similar site is your best chance. again if you only have USB because the lead contains electronics perhaps the USB might not have enough power, however, many do or sometimes the PLC has a supply buit in to the connector like Mitsubishi so the power comes from the PLC.
Hello, I have a problem with my Twido twdlmda20dtk, when I turn it on all the leds go crazy. Any idea what can be wrong or how to diagnosticate...
1,419
Hi I am twido PLC TWDLCAA24DRF and HMI HMIS5T . Confugured HMI as master and twido as slave on modbus RTU. Parity none,stop bit1,data bit 8...
1,301
Hi all you clever people. I have a program line that does not make sense %MW401 < %MW402------> (%M2) - [%M2 = ON] Which does not make sense (20...
2,827
Hello, I need help with Twido PLC. This PLC is for the fountain controlling lights, water level, etc. Some time ago water solenoid valve coil...
3,168
Hi All, I have already Posted regarding Twido But no one replied. Please Tell my Twido Mac address is 0080F4832372 & by the conversion of Last 2...
1,945
