Twido twdlmda20dtk problem
kimd41
Dec 2019
spain
Hello,
I have a problem with my Twido twdlmda20dtk, when I turn it on all the leds go crazy. Any idea what can be wrong or how to diagnosticate it?
Thanks!
This model is at end of life, It sounds like a power supply problem. Check power to the unit but I bet it's the internal PSU it seems likely that it has it's own 240v (assume that is supply) or 24v if it is a 24v unit and this will provide the voltages for the electronics It sounds like it is pulsing i.e. there is an overload caused by the circuitry. Most processors will run on 5, +12 & -12 and these supplies are often switch mode with crowbar over current.
Thanks a lot for your reply, I will check the PSU. Do you have by any chance some sort of diagram or documentation about it?
Cheers.
Hi guys!! I'm New here and new with this type of plcs i have TWDLMDA40DTK and i need to get a copy of the program and i don't have an original...
689
Dear friend, how to read the input register (3xxxxx) of device from twido plc. i have tried the comm macro but it always read the holding register...
1,569
Good, how do I control through an Analog output of a valve, that is, open the valve from 10% to 10% until it reaches 100%, and then close it...
2,242
Hi! I bought a secondhand Twido base unit to help me learn programming and also faultfind expansion modules (one of my customers machines uses...
1,691
We're a second hand machinery merchant. We've just had a machine arrive that has a Schneider Twido TWDLCAA24DRF PLC and a Magelis XBT-R411 HMI...
2,402
