Profibus PA to DP
electro89
Mar 2012
Canada
106
Anyone know of a way to communicate Profibus PA devices to a Profibus DP network? I am using the CTI2500 processor and they do not have a card for converting PA to DP.
Check with your Siemens distributor. (Franklin / Ontor ?)
I think the cat number is 6ES7 157-0AC82-0XA0, but that might not be right.
Have a look here. You will find all you need.
What is required depends upon your specification.
You can use DP/PA coupler or DP/PA Link. If you use a coupler you need to bring the DP speed down to the PA speed (45.45kbps). If you use a link the DP speed does not depend on the PA speed.
If you want to make a redundant PA ring then apart from the links you need Active field distributors (AFDs).
How many instruments will you use? what type and what PLC.
If I remember well the maximum PA devices per coupler is 32.
Regards
Thanks Mike_RH for your answer, I'll look into that.
grnick50, I connecting to 4 devices and connecting to a CTI 2500 PLC.
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
181
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
83
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
107
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
319
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
318
