S7 Device Proxy Profibus Diagnostics
rob63
Mar 2015
uk
69
I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA.
Everything I’m currently trying to display works well.
I would like to create a page for profibus diagnostics. In previous projects that have solely been created in TIA I have dragged the stethoscope icon to a new page, compiled/downloaded and all information is displayed.
For some reason in the device proxy project the diagnostic window is blank, I have read elsewhere this should work, I’m not sure what I have done incorrectly… Is there an additional setup required?
It's possible that it only works for integrated 300s vs device proxy, but my guess is that you imported the tags but not the alarms or something.
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
60
Hey guys, I have to take an upload of a program on an S71200 PLC to change a hardware config option and then redownload the program with this...
111
Hi, First time poster, long time reader. I've got a mass flow controller device for controlling the flow of gas. It has a flowmeter and an...
276
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
582
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
144
