how to take the data from level transmitter to analog input omronCS1W-AD16?
kartika
Jul 2011
Lampung
31
hi all...i'm still confusing about scaling in PLC..need ur help, please..
i have a differential level transmitter, the signal is 4-20mA,and analog input Omron CS1W-AD161-V1 (16input channel), CS1G-CPU45H, how can i take the data from the level transmitter to the analog input use SCL instruction?
thanks for the attention
hi all...i'm still confusing about scaling in PLC..need ur help, please.. i have a differential level transmitter, the signal is 4-20mA,and analog...
4,583
Hi guys I have Productivity Station which will collect Run time data from Phoenix input block "ILB ETH 24 DI16 DIO16-2TX". I am new to crimson...
2,919
141
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
67
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
50
