Crimson 3.1 - Strange Array Behaviour
I
I've got to get a life;).
No, this is gold for me, I've written a couple of programmes in Crimson over the years, but have always felt the code was messy and probably incorrect, my background is PLC.
The plant only runs 5 days a week (0 ==Sunday:nodi:)
So starting with seconds means it will only look at the next statement every minute instead of every tick? Aww man I've got a lot of code to correct!
Thanks for taking the time. :geek:
So there are a few choices
  • if (.Day>0 && .Day <6)
  • if (!(.Day<1 || .Day>5))
  • if (.Day%6)
  • if (MOD(.Day,6)>0)
I dunno about correct syntax; I suspect the first two are faster, but as the inner tests executing only seven times a week it will not matter. That said, the last two are just cute and so should be avoided.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
122
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
206
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
107
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
91
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
89
