PanelView Plus 7 Trend Display History Intermittent Issue
BAJ
Jan 2006
Maple Grove, MN
201
I have seen this on a couple different machines we've installed recently at a customer site using the 15" PVP 7 Performance series, v10 f/w. The machines are completely different configurations as they are different steps of a manufacturing process.
The trend screens are setup to use the DataLogger history and it works, but at some point during commissioning we will randomly be missing the history for some tags. Power-cycle or re-downloading the MER (even the same MER) will often correct this, sometimes it fixes the history for some tags but breaks others. The DataLogger is collecting the data for all tags all the time as history that was previously missing will be displayed after a power cycle/download (for the same time period) and we have also looked for issues exporting the data with FT File Viewer. We haven't modified the DataLogger for quite a while on most of the systems, mainly just making small display changes, yet the problem still seems to come-and-go.
The common threads here are they are all the same PVP 7 model, all v10 f/w, and have all had the MER modified by me (my computer).
Any thoughts?
Thanks,
-Brad
Just heard back from my distributor's support team and they have seen this issue too. Can probably cross "my computer" off the list of potential causes.
Hi, guys, how’s going? I added one “Trend Object” on screen A in PanelView Plus 1500. Then configured “Refresh Rate”, “Buffer” ……and set up...
1,913
My customer wants to see the time AND date (rightfully so) because we have the trends set for 3 days, but it's only showing the time. Can't we...
1,356
Hello all, I have a process that happens pretty quickly......about 1.5 seconds of time per cycle. I want to collect data from an analog input...
1,624
Hi, I notice that the PanelView Plus has memeory slot, something like our pcmcia slot. I'd like to ask if it's possible to store TREND data in...
5,606
81
