Panelview Plus Trend Sample Rate Limit
scarince
Jan 2009
Dayton, OH
152
Hello all,
I have a process that happens pretty quickly......about 1.5 seconds of time per cycle. I want to collect data from an analog input and display it in a trend on a PV1000. In order for that data to be meaningful, I think I need to grab a sample every 100ms if not faster because it is very dynamic. I understand how to do trending on PV, but do not have it set up yet for this application.
My question is, what is the fastest practical speed I can expect to be able to log from the PLC to the data log model? I'm pretty sure it was never meant to be a high-speed data collection system, but I wanted to ask before I made the investment in setting it up.
If this is way beyond the ability of the data log model, then do you think I could "buffer" my data to an array and then play it back for the data log by writing my stored values to the pen tag at a rate slow enough for it to be displayed? I know this wouldn't be real-time, but that would be okay. Has anyone done this sort of thing?
Thanks.
Bill
I have done exactly that - collected data at the PLC's scan rate and then spoon fed the data into an array that the PV points to for the trend at a 100 mSec rate.
I have seen this on a couple different machines we've installed recently at a customer site using the 15" PVP 7 Performance series, v10 f/w. The...
1,722
Hi, guys, how’s going? I added one “Trend Object” on screen A in PanelView Plus 1500. Then configured “Refresh Rate”, “Buffer” ……and set up...
1,922
My customer wants to see the time AND date (rightfully so) because we have the trends set for 3 days, but it's only showing the time. Can't we...
1,358
Hi, I notice that the PanelView Plus has memeory slot, something like our pcmcia slot. I'd like to ask if it's possible to store TREND data in...
5,610
97
