RheinhardtP
Dear Friends,
I have the following situation which I find very strange with an ABB VSD that we are using on a hoist. The situation is as follows the hoist basically stacks plates into different bays..
Now the VSD that control the hoist motor was actually working fine till the following happened.. When the hoist move upwards everything is fine and it controls at the required RPM .. The problem is when I move downwards the unit just accelerates over the Maximum RPM and then Trips on Overspeed Even when adjusting my Maximum Speed Down to 600RPM the motor accelerates over 1500 RPM.
When I manually release the brake the unit starts moving downwards slowly which means my Gearbox is obviously not maintaining the weight of the hoist
Question
Any advise would be well appreciated.
Kind Regards
Question
- What could cause this to happen.. No Parameters were changed on the VSD. Could it be a Hardware issue, or a faulty VSD
- Would changing the GearBox ratio help with the effect that Gravity has on the hoist and limit the acceleration.
Kind Regards
