ABB ACQ810 VSD Start Enable
Nov 2016
Kinross
Hello All,
Not exactly a PLC question but more looking for advice on a PROFIBUS controlled ABB ACQ810 VSD.
The drive is controlled over the fieldbus network and the command word is all correct and the speed reference can be seen at the Drive when in remote but the drive will not start. No voltage out to the drive or current feedback at all.
The activity arrow has a dotted line which indicates that it is not receiving the run enable.
The parameter for the run enable is 10.11 and it is pointing to an address which is A.430.000, Does anyone know what this parameter is actually pointing to as I cant find A.430.00 in any of the manuals. I thought perhaps it is a active programming address but I have no real idea.
The drive will also not start in local mode either direct from the control panel so I think the comms network is fine.
Any help would be much appreciated.
Thank You
Are you referring to estop enable or S1 and S2 estop enable?
then this is a wiring issue and would not be a command word not toggling off and on.
All drives have a hard wired enable signal from estop unless its some estop network for your drive like profinet?
Or are you dropping the estop contactor back in main panel and this is a remote drive at motor?
You tell us how its designed I am just guessing now.
Hello All, Not exactly a PLC question but more looking for advice on a PROFIBUS controlled ABB ACQ810 VSD. The drive is controlled over the...
1,125
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
90
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
147
Hi hoping someone can assist me with current issue I am experiencing with an ABB drive. Problem I’m experiencing is a ABB drive supply a large...
211
Hello all, I have an ABB PLC (PM573) and it has without MC card. I need to take backup from PLC to PC (in automation builder v2.7 ). My...
448
