Omron Sysmac CJ1M
lesmar96
May 2017
PA
520
Good Afternoon!
Looking at the possiblities of connecting to an older Omron Sysmac CJ1M CPU11 plc. Customer will provide the program. It looks like CX-One is the correct software for these plcs? Also what is the best recommendation on cabling? doesn't look like off-the-shelf cables will work?
Yes CX-One, is there a separate card with an ethernet port in the rack? There's a DB9 on the CPU, a standard or null modem cable might work...
For connecting to the peripheral port, the original Omron part# is CS1W-CN226
For connecting to the other port, the original Omron part# is C200H-CN229-EU
Maybe @geniusintraining might double verify this, this site has the cables available:
https://www.plccable.com/omron/
The CS1W-CN226 is a serial cable, not sure if you have a serial port.
Other cable should be C200HS-CN220-EU.
I would have to check but I am sure the C200H-CN229-EU will not work.
@geniusintraining will be able to help.
I am a new user of Omron PLC. I am facing trouble while connecting my Laptop (Siemens Field PG)to Omron Sysmac Cj1m CPU22. I am using CX-One...
4,953
Hi everybody, I can't transfer data from laptop to omron sysmac cj1m cpu11. I use cable "omron cs1w-cn118" and Uport 1150 (RS232),I sure software...
3,931
I've programmed both the MP277 and CJ1M CPU12, but I can't make them to communicate. I've tried configuring their addresses and nodes, Baud rate...
3,120
Hi, I did a search forthis on the site and found a link to page 1728 but not post about this??? any answers? Thanks, Steve
7,394
I took an online course but don't remember covering this. How do I access the system clock in a compare instruction? I want to turn on an output...
537
