Omron PLC Sysmac Cj1m CPU22
sajjadgazali
Jun 2009
10th of ramadan
I am a new user of Omron PLC. I am facing trouble while connecting my Laptop (Siemens Field PG)to Omron Sysmac Cj1m CPU22. I am using CX-One Software and I have Serial cable (Combination of USB to serial 9 pin cable) my laptop have 25 pin Serial port and several USB port. I try to connect Omron PLC by Serial 25/9 pin adeptor and also tried to connect by USB to Serial converter cable. But every attempt is failed. My Computer did not connect with Omron PLC (Even in Auto Search also).
My Computer running Windows XP SP2 version. Please someone help me to find proper cable connection drawing (9D to 25D pins)and proper settings for Computer/PLC communication.
Thanks,
Welcome to the forum.
The Omron 9 pin connector is NOT a standard pin out.
Please see the attached document for the required pin out.
Hope this will help.
I have a Mnemonic code for the above PLC. I wish to convert it to ladder diagram but the code is a bit complex. I am looking for someone to assist...
17
5,711
I'm taking some time today to learn how to edit a customer's Omron PLC program. My customer has a machine that is used infrequently during the...
2,874
Dear Friends. I need the information about a omron sysmac C60K PLC , which communication cable can be used to its programming, & whats the...
4,345
Hi All, need a little help in here.I never program PLC before but at the moment, I am task to backup PLC program on our machines which is using...
5,697
omron plc sysmac c40p alarm and power led lit continously doesnot go in run mode please give me solution on it:lolis:
2,821
