CompactLogix communication to CompactLogix via ethernet
dmroeder said:
I prefer Produced/Consumed tags over message instructions.
Agreed, I too prefer Produced/Consumed tags except in situations where the PLC cannot be put into program mode to configure the produced/consumed tags such as in operations that run 24/7
Good point. It's too bad you can't create them online, or even in program mode. I dislike downloading.
Yes thats the nice feature about Logix. You don't need to write logic to communicate between to PLC's. Just create the tags using the proper data type, make sure the 2 PLC's are on the same network and setup the properties of the tags. The consumer does most of the work. The producer just lays the tags out there for anyone wanting them.
Hi All, I have a requirement of communicating my 5380 CPU with Zebra ZT411 Printer. Is there any one who did this before ? Do we need to have...
919
Hi There Folks, Would like to know if any of you have ever attempted doing this: having CTI2500 communicate with a compact logix5335E. How would...
8,658
Hello everyone, I hope you are well, I have a CompactLogix 5380 PLC (5069-L310ERM) and I would like to communicate with a PanelView 800 HMI...
716
Hello, I have a COMPACTLOGIX 5370 and a PV800 (2711R-T7T) in a panel. When I power cycle the panel the PV800 display boots up before the PLC and...
1,328
Hello, I have CompactLogix 1769-L27ERM and I can not communicate with it using Ethernet port (1 or 2). Just to clarify exactly what is going on. I...
2,032
