Siemens S7 Redundant system interface using Modbus communication
PLC_talk
Oct 2006
p
50
I need some help to communicate the S7-400 redundant system using CP441 to third party devices on Modbus protocol.
We have following configuration -
S7-400 redundant system having 2nos. CP441-2 in each CPU rack.
The first CP441 is networked to Device 1 as PTP1
The second CP441 is networked to Device 2 as PTP2
As this is redundant PLC the 2 CP441 in the standby rack are networked as - Device 1 as PTP3 , Device 2 as PTP4
The logic addresses for lead CP441's are 1000 & 1001
& standby CP441's are 1002 & 1003
Here's the problem -
The Modbus protocol requires a ladder call to individual CP441 modules to be written in OB1. Do I call all the 4 modules seperately or call just 2 modules in the lead processor?
How do the standby CP 441s seamlessly takeover once CPU becomes lead?
I am unable to connect the standby 2 CP441s to PTP1 & PTP2. Also it does not allow me to configure same logic addresses of 1000 & 1001.
Do I assign same slave addresses for the standby CP441s as in lead rack?
Would appreciate any help on this.
Thanks in advance.
Pally
Hi all, I'm strugglin with mtbf calculation for my system, that is a siemens sistem H with double central rack and double et200M redundant on...
1,513
Hi, I am currently running two S7-1515R, in redundancy connected with devices through an MRP ring. One of the devices that are connected to the...
1,490
Hi guys, I've a set of Siemens 414H redundant PLC at a client site. It has a redundant Ethernet networking for SCADA (winCC) and other S7300 CPU...
3,577
Hi, I'm new to software redundancy. I have two 315 2DP Cpu's that should connect to two IM 153-2's. I have 8 I/O modules that I would like to...
5,179
I have two siemens S7-417H cpu’s that run as a redundant pair. On the project tree menu both cpu’s are shown but only one S-7 program shows under...
6,174
Junsheng Liu
J
