Siemens S7-417H redundant cpu
Andy32821
Aug 2003
Orlando
I have two siemens S7-417H cpu’s that run as a redundant pair. On the project tree menu both cpu’s are shown but only one S-7 program shows under one of the cpu’s. I have made programming changes to this S7-Program.
My questions:
Do I need to somehow save this revised program to the backup cpu?
If so, how do I do it?
The cpu’s have a memory card in each cpu.
How do I save the revised program to these cards?
Thanks, Andy
Hi, there:
Depend on what kind of memeory card you use. If it is a RAM memory, you can simply download your revised program into CPU because CPU's RAM and your RAM card are simply merged together.
If you use a Flash memory card and your CPU memory is big enough say 1 MB, you can simply download your revised program, and then copy from RAM to ROM.
Hope it can help you.
Best regards,
Jason
G
I am working on a project where there is an S7-417H PLC with ET200 I/O on redundant profibus. One of my I/O drops has 1 pair of existing fibers...
7,005
284
162
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
312
125
