Siemens redundant Ethernet loss comm signal
flyers
Sep 2006
Amk
295
Hi guys,
I've a set of Siemens 414H redundant PLC at a client site. It has a redundant Ethernet networking for SCADA (winCC) and other S7300 CPU comm purpose. If I disconnected one Ethernet cable (the standby cable) can the SCADA prompt an alarm?
Thank you.
Hi, I am currently running two S7-1515R, in redundancy connected with devices through an MRP ring. One of the devices that are connected to the...
1,493
Hi all, I'm strugglin with mtbf calculation for my system, that is a siemens sistem H with double central rack and double et200M redundant on...
1,524
Hi, I'm new to software redundancy. I have two 315 2DP Cpu's that should connect to two IM 153-2's. I have 8 I/O modules that I would like to...
5,181
Hi, I need some help to communicate the S7-400 redundant system using CP441 to third party devices on Modbus protocol. We have following...
6,048
I have two siemens S7-417H cpu’s that run as a redundant pair. On the project tree menu both cpu’s are shown but only one S-7 program shows under...
6,176
Junsheng Liu
J
