Hello All!
Please help me figure out how to use multiple recipes in the same FT project.
My cell contains two production lines and I`d like to create an independent recipe for each of them. I created two screens and put Recipe Plus components from the library on each screen.
Using recipe Plus Editor I created a couple of recipes and ingredients.
The idea is to display Line 1 recipe on one screen and Line 2 recipe on another screen. The problem is that when I test my application I can see all my recipes and units in both recipe screens, so I have a mixed list in each recipe.
Is it possible to split recipes (units) in a way that I could see only proper recipes on each recipe screen?
I used to work with Siemens and Omron software and recipes is a standard option there, that is easily configurable, so you can create as many recipes as you need. I thought the same principle is used in FactoryTalk View ME. Either I do something wrong with a recipe configuration or I don`t correctly understand the meaning of the recipes use in this software.
Any help is appreciated!
