PowerFlex Serial Converter
rbkief
Jun 2004
We have purchased the PowerFlex Serial Converter Kit which included the 22-SCM-232, 22-RJ45CBL-C20, and 1203-SFC.
I can't seem to locate the the 22-RJ45CBL-C20 which I came with the kit, therefore I replaced it with a standard RJ45 patch cable (straight through cable) trying to do parameter(s) backup on PowerFlex 4/40's but not able to communicate using Drive Explorer or Drive Executive.
I also tried using a X-Over RJ45 cable but no luck.
I went and tried using Hyper Terminal, and able to communicate with the Serial Converter (able to display the unit's parameters) but not with the PowerFlexs.
I have checked the communication settings on Powerflex and matches with my serial. Thus 8-none-1 @9600 baud rate.
Can anyone see what I am doing wrong?
Is it my cable? If so.. can you tell me the Pinout on the RJ45 cable so that I can make one.
Thanks in advance
Rey
Fairly new to the drive so apologise for the layman terms. Textile machine uses PF525 VFDs to control motors. The speed of the drive is currently...
137
Hello Everyone, I want to upgrade the firmware of Powerflex 40 from 5.001 to 6.002 can anyone tell me how can I do that?
73
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
252
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
201
Hi, I'm currently having issued with a PowerFlex 252. It was working fine last week, and suddenly decided to stop working. When I go into...
189
