AlfredoQuintero
Hello. I am dealing with an issue with the ModuleStates function. My program passes the value "1" to the parameter LADDR. This value "1" is set for the "Device Number" setting in the IO configuration. Nonetheless the ModuleStates function returns error code 16#8091 [Hardware identifier of the LADDR parameter does not exist. Check (for example, in the system constants) whether the value for LADDR exists in the project].
I have also tried the values shown in the system constants for this PROFINET IO device with same results. What is wrong with my use of this function, I wonder.
