Unexpected termination of RSLinx Classic
rsquestion
May 2020
Italy
will appreciate your help with my problem.
After years of usage our RSLinx starts to stop unexpectedly. It is possible to start it but it stops again and we don't know why. We are able to run it as app without problems but it fails when comes to service.
What I see in the logs:
Could not load language specific resource DLL [....], reverting to English. - I guess it is not the issue as it started to appear before we got this problem as well
The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
The RPC server is unavailable. (Exception from HRESULT: 0x800706BA)
What we did:
set automatic restart of RsLinx after two failures - did not help
deleted Harmony files - any influence observed, I guess constant deleting is not the solution
reinstalled the server + RS Linx - did not help
installed new version of RSLinx - helped for a week but now the issue appears again
check if RPC is set to automatic, DCOM server process launcher to automatic and RPC launcher is set to manual
What I found was an advice about registers - we need to check it.
Any suggestion?
[FONT=&quot]Thanks.[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot][/FONT]
[Update: fixed a typo in the image.] See the image below, especially the blue-ish annotations. The three rungs ending in output coils -( ) are...
17
992
Hi all, I've run into an error I haven't seen before while attempting to download the “Programming” tab of RMCTools to an RMC200 Lite I just got...
3,674
First, a background on the equipment so you know what is going on. I have an AB ControlLogix L63 processor controlling some Mitsubishi...
17
6,028
Hi, I'm getting a bunch of these warnings when I build the program in Connected Components Workbench. The program is legacy code. The program...
2,394
Hello. I am dealing with an issue with the ModuleStates function. My program passes the value "1" to the parameter LADDR. This value "1" is set...
1,616
