FactoryTalk View SE Find All Controller Tags Used
i_am_bs
Oct 2011
Saskatoon, Saskatchewan
I'm trying to get a list of all of the tags (both HMI and controller) that are used in a FT View SE project. I think when you export the HMI tags, it may tell you (I haven't actually tried yet) but I haven't found a good way to do this for controller tags.
The best I've found so far is to select all on a display in Studio and the open the Tag Substitution window. This is OK but it doesn't allow you to export them or see where they are used.
The only other option I've found is using the object explorer to go through every object.
If anyone has any ideas, I would greatly appreciate it!
There's an external utility called the Project Documentor that lists all the tags and the displays and objects that use them. It launches from the FactoryTalk View -> Tools menu and was included first in v5.0.
The Project Documentor presents you with a tree schema of the FTView project from which you select which objects or features you want to document. Then you "Export" the report to an HTML file.
It's not as convenient as a "cross reference" function would be but it does work. It's one of the only easy ways to weed out missing/readdressed tags that inevitably show up during debugging and growth of a large Logix control system.
Thanks Ken!
I guess it is now called Application Documentor and it doesn't show up under tools in the start menu or under tools in Studio but I found it the good old fashioned way in My computer...........\ADLauncher
Thanks Ken!
Hey, where is it now then?
Thanks!
-PeeLC.
Thanks!
-PeeLC.
If you are using FactoryTalk View v5.10 or later and looking for the Application Documenter then navigate to...
Start>All Programs>Rockwell Software>FactoryTalk View>Tools>Application Documenter
...or the equivalent path under your Operating System.
Regards,
George
Good Morning , I'm working on a HMI project , and for some reason I cannot find some tags in the Tag Browser. Has this happened to you...
3,010
Not sure why this View Studio can't see the CompactLogix L33ER on the right side of the shortcut assignment window. It can see it on the left...
7,484
Hi, folks, how is going? There are two PanelView Plus 1500 over our production line and they work well. Today I edited the...
10,785
How can I find the designated tag which is created in RSLOGIX5000 in Factorytalk view studio software? I want to know which screen uses this tag...
10,075
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
80
